Where do I run the wire??? 2007 Accord V6 4dr Navi
Old Feb 23, 2010 | 02:17 PM
nightowlll2010's Avatar
Default Where do I run the wire??? 2007 Accord V6 4dr Navi
I am trying to install a power inverter as I travel in my 2007 accord and carry a laptop. Often times I am without power and need to install a power inverter. I can do all of the wiring without any problem but I'm just not sure where to run the wire to get from the battery to the passenger or driver front seat which is where I plan to install the inverter. If anyone knows where an ideal location would be to drill into the firewall please let me know. I would appreciate your help as I am at a road block here until I feel safe drilling in a good area. Please email me here or directly at ocrj2008@gmail.com thanks in advance everyone!!
O
Old Feb 23, 2010 | 05:15 PM
korrupt1's Avatar
O
You can look on the firewall from engine side and then move into interior area...should give you a pretty good guess area of where would be clear
I had the same issue on my 91 legend...found what looked to be a ideal firewall area and went in the interior and sorta dimpled it with a screwdriver to insure a clean spot.....worked in that case very well
rinedog
Mar 16, 2012 02:17 PM
cyberdork
Apr 8, 2009 11:40 AM
bangandow
Oct 14, 2006 06:22 AM
ugotjewed247
Apr 22, 2006 02:35 PM
Burn69
Nov 14, 2005 09:34 PM
