hole to run powere wire 2006 accord 4dr
Old Apr 19, 2006 | 12:56 AM
ugotjewed247
Default hole to run powere wire 2006 accord 4dr
where could i run this wire also where can i get a loc (line out converter for this car
Old Apr 19, 2006 | 01:23 AM
marbro's Avatar
Default RE: hole to run powere wire 2006 accord 4dr
tap into the ignition wire that goes to the deck
Old Apr 19, 2006 | 04:56 AM
Patrick111487's Avatar
u can prob get a LOC from ur local car audio shop.. thats where i got mine
Old Apr 19, 2006 | 03:31 PM
lightshow's Avatar
there is a rubber boot under the glove box that you can run a wire through
Old Apr 20, 2006 | 02:11 AM
marbro's Avatar
is there a signal wire to shut it off when the cars off? if there isnt probably would be better to tap the deck ignition wire.
Old Apr 22, 2006 | 02:43 AM
ugotjewed247
well where is this rubber boot with more description and do the door sills pop off cause i have to run the power wire if i get it thru the firewall
Old Apr 22, 2006 | 02:35 PM
marbro's Avatar
under the hood, the gromit is on the passengers side behind the wheel well. I dont know if you could see it by removing the glove box because the heater core is right in front of it. What i did was fish it throught with a coat hanger
chelseym502
Jun 25, 2010 07:14 AM
nightowlll2010
Feb 23, 2010 05:15 PM
cyberdork
Apr 8, 2009 11:40 AM
bangandow
Oct 14, 2006 06:22 AM
Burn69
Nov 14, 2005 09:34 PM
