fast blinking signal lights!
Old Mar 9, 2006 | 08:25 PM
thunder_x's Avatar
Default fast blinking signal lights!
how do i make my signal lights blink so fast?
i heard you change the wires, but i dont wanna do it myself and mess it up
is there a place to go to to do it for me?
im from southern califoria
im looking for a plce in the san gabriel area
thanks...
Old Mar 9, 2006 | 08:27 PM
sir_nasty's Avatar
Default RE: fast blinking signal lights!
Most blinkers are reliant upon resistance for speed.... There is a small resistor that controls it (I don't know where it's at on your exact model) you can see this by simply removing a blinker light and watch the other one on the same side start blinking faster... So you need to figure out a way to decrease the resistance or get a different blinker switch thingy (how's that for technical jargon!)
Old Mar 10, 2006 | 12:25 AM
fryhead's Avatar
Default re:
I dont know of any shops that do that
Old Mar 10, 2006 | 12:28 AM
19Accord97
Default RE: re:
If you want them to blink fast you could always replace the bulbs with one of l.e.d sockets (usally around 8 bucks)and they will last longer. Simply type in your bulb # on eBay and a few l.e.d ones should come up, but make sure they have a high MCD (brightness) rating. Also, don't install a Load Resistor with it and it will blink alot faster. Hope that helps!
Old Mar 10, 2006 | 03:33 AM
lightshow's Avatar
Default RE: re:
your flasher in the steering column controls the rate of the blink. i dont think you should mess with it, any speed shop should be able to mess it up though.
Old Apr 5, 2006 | 03:51 AM
19accord95
Default RE: re:
I have a 95 accord and mine blink fast and dont know why? I checked everything?????
Old Apr 5, 2006 | 08:33 PM
sir_nasty's Avatar
Default RE: re:
9 out of 10 times when your lights blink really fast I swear it's a light out or a bad ground.... the last possibility is the blinker relay as far as I'm concerned... or on occasion it could be the wrong bulb...
Old Apr 25, 2006 | 02:55 PM
steev's Avatar
Default RE: re:
http://www.7thgencivic.com/forums/sh...ad.php?t=24199
here's how on a civic, can't be much different.
-s
Old Apr 25, 2006 | 10:27 PM
legionofone's Avatar
Default RE: re:
yup LEDs do the trick mine blinked hyper fast on my cirrus...
royalmay
Jun 17, 2022 12:38 PM
PatBB
Aug 31, 2012 10:35 AM
mvickky
Jul 6, 2009 06:59 AM
thunder_x
Nov 30, 2007 12:57 PM
aghigig
Nov 20, 2005 03:04 AM
