Turn Signal Blinking Fast on One Side
Old Nov 7, 2005 | 07:53 PM
aghigig
Default Turn Signal Blinking Fast on One Side
I have a 2000 Honda Accord. My driver's side turn signals are blinking faster than normal. I have replaced the front bulbs and that did not help. I also switched the back two bulbs and the fast blinking did not change sides. I am thinking that the turn signal relay needs to be replaced but I am not a car tech. Thanks.
Old Nov 9, 2005 | 01:50 AM
Evlampius's Avatar
Default RE: Turn Signal Blinking Fast on One Side
there are 2 bulbs at the front
Old Nov 9, 2005 | 04:40 PM
dinzer's Avatar
I had this problem with my 2000 also. you need to check all the bulbs in the headlight assembly.
Old Nov 11, 2005 | 01:49 AM
7thGen's Avatar
Gennerally one of the two front bulbs being out won't do this. Check both bulbs first but it may be the switch. When the relay goes it will mess with both sides.
Old Nov 20, 2005 | 03:04 AM
jayallen40
I have not had that problem with my Honda, but I know other cars have whats called a flasher for each right side and left side. When they start to go out the turn signals start to flash fast. If your honda has this it would be located up under the dash by or in the fuse box. It will be a silver meatal round or rectangle box. About the size of a qurter and about half inch deep.
royalmay
Jun 17, 2022 12:38 PM
mvickky
Jul 6, 2009 06:59 AM
bmacb
Dec 28, 2007 10:09 AM
thunder_x
Nov 30, 2007 12:57 PM
thunder_x
Apr 25, 2006 10:27 PM
