Sponsored by:
Sponsored by:
08 Accord Coupe HID Install
Old 08-07-2010, 09:37 PM
WannabeMugen's Avatar
Default 08 Accord Coupe HID Install
I have just installed some Notto HIDs on my 08 accord coupe (2.4L Std.) They work great whenever I have my lights on(I put them in my high beams, not the projectors(rookie move I know)) but whenever I turn the lights off they flicker. In the install guide they said to troubleshoot that by install at least 20a fuses. I only had a spare 20 and 30 so I threw both of those in and still have the flicker. Do I need some capacitors as well?
Here is the exact kit I bought for 9005 bulbs.
http://www.carid.com/2008-honda-acco...kit-67569.html
Old 08-09-2010, 06:32 PM
So I still can't troubleshoot my problem. Any thoughts?
Old 08-09-2010, 07:33 PM
Did you install the HIDs with or without the relay harness?
Old 08-09-2010, 09:06 PM
With. That's what has me super confused.
Old 08-09-2010, 09:22 PM
I have never installed HIDs on my car. Weird electrical problems can arise from bad grounds and/or poor connections.
I would clean off crud built up on the battery terminals and make sure that that the connections from the HIDs to the battery are clean and tight. Also clean off all ends of both battery cables just to be thorough.
An D. Nguyen
08-13-2013 09:59 PM
Josh Lillywhite
04-02-2013 05:34 PM
sneh517
01-15-2012 09:32 PM
Alo Gallagher
07-13-2010 04:28 PM
sneh517
05-27-2010 02:14 AM
Quick Reply: 08 Accord Coupe HID Install
