97 Accord: dash showing HI beams on but NO HI, only low beams work
My 97 accord is opposite, low beams work and idiot lite on dash works showing HI beams on but NO HI beams , low only on ,in either position (lo/hi)
I moved your post to a new thread.
Your issue may be more than one thing not working properly.
- For the high beams not working, check that the high beam bulbs are good (i.e., not blown).
- For the high beam indicator staying on, it can be possibly either a short in the dimmer relay, a faulty combination switch (there is a dimmer switch and flash-to-pass switch as part of the combination switch), or wire short to ground (e.g., exposed wire touching ground). If you pull the dimmer relay and the high beam indicator does not stay on, then it is most likely not a wire being shorted to ground.
