Lower control arm
Old Nov 10, 2008 | 08:21 PM
Am4wag's Avatar
Default Lower control arm
In order to remove the lower control arm/replace the bushing,does the brake caliper have to be removed?I have'nt looked at it,but if I need to remove the caliper,I'm going to service the brakes/order brake partstoo.
Old Nov 10, 2008 | 08:29 PM
cjdm98's Avatar
Default RE: Lower control arm
No it doesnt need to be removed, but since your doing the job, you may as well do brake service.
Old Nov 11, 2008 | 01:40 PM
klrspz's Avatar
Here's a good pic of it:
http://filtsai.com/accord/suspension...on_parts_1.jpg
Might take some muscle grease to get it down enough though...
Old Nov 11, 2008 | 02:28 PM
kris_loehr's Avatar
If the bolts are seized to the bushings it can be a pain. I would at least have the bolts on hand when doing the job. I have seen them removed with a torch but the rubber around the bushing burns and is quite messy. The other way is to cut them with a [/b]die grinder with a disc(you need a large size diameter) or something similar. On the frame one you would first break the bolt free. It will spread the subframe a little if the bushing is seized to the bolt then cut(cut through bushing and bolt) it off but leave enough of the bolt to get a vise grip on. You will mostly have to heat up the threads to get it out with a vise grips. I used to work next to a Honda Tech at a dealership and watched the various ways jobs were done. I did all brands of vehicles for the used car department. [/b]
Old Nov 11, 2008 | 06:32 PM
Am4wag's Avatar
klrspz,that IS a good shot....However,where I have alot of the endplay is to the left of that pick (unseen),where thr lower control arm mounts to the mainframe(?).
Old Nov 12, 2008 | 09:51 AM
klrspz's Avatar
Ahh my bad; don't have a shot of that on hand...
DJ NVS
Dec 17, 2009 07:41 PM
mtnbay
Jul 20, 2008 03:22 AM
oma93
Feb 13, 2008 09:19 PM
Steve93
Oct 19, 2007 05:02 AM
RoKnAzn
May 21, 2007 06:29 PM
