Sponsored by:
Sponsored by:
Humming sound when accelerating
Old 07-02-2011, 08:28 AM
bvh20's Avatar
Default Humming sound when accelerating
I have a 98 Honda Accord. I hear a humming sound when I accelerate. It usually starts around 20 mph and continues until I slow to speeds below 20. It shifts, but seems to be a little slow to accelerate. Any ideas?
Old 07-02-2011, 12:09 PM
Could be tires or a wheel bearing? Have the tires rotated and see if the "sound" moves. Also while the tires are off check the wheel (hub) bearings
Old 07-02-2011, 07:20 PM
Tek310's Avatar
I had the same problem. Turned out to be the vacuum hose that comes from fuel pressure regulator strings around and over and goes through the intake air resonator was being crimped by the battery sitting on top of it.
Caused a whine/whistle sound like you described
Old 07-02-2011, 08:49 PM
piggylover1985's Avatar
Check the wheel bearing, i just replaced a rear wheel bearing on my 98 and also a front wheel bearing on my 02 accord V6.
squi
12-07-2009 01:51 PM
HundaAccode
12-09-2007 09:45 PM
asphyxxed
01-09-2007 06:42 PM
ckebottle
10-11-2006 07:49 AM
Quick Reply: Humming sound when accelerating
