head lights problem need help please
Old Jun 3, 2006 | 08:24 AM
87Accord LXI
Default head lights problem need help please
HI ok this is my problem on my 87 Accord LXI when I first bought the car all the lights worked but now the passegr side low beam wont work but hi beam dose I replaced bouth head lights and stil dose not work any help would be great . And one more thing it is a 5 speed car when I shift from 1st to 2nd it will grind a little any clues/ help would be graet thanksn
Old Jun 3, 2006 | 11:51 AM
Chiovnidca's Avatar
Default RE: head lights problem need help please
ORIGINAL: 87Accord LXI
Check your fuses. But likely the wiring could be broken behind the bulbs from bending back and forth turning the h/l on and off.
Old Jun 3, 2006 | 11:53 AM
Chiovnidca's Avatar
Worn syncro maybe? I'd just shift it a little easier, lower rpm.
Old Jun 3, 2006 | 02:23 PM
deserthonda's Avatar
ORIGINAL: Chiovnidca
yep i agree with Chio.. i have seen it many many times,, the fuse also is problably blown,, cause when the wiring shorts it blows the fuse.
what you need to dois, remove the hed lite, open the wriring harness and at the bend, that;s where the wiring breaks, repair it, make sure to route it so it has some slack , so when the bucket goes up or down does not stratch the wiring .
And i agree as well on the worn syncros inside the tranny..
Old Jun 4, 2006 | 08:58 PM
87Accord LXI
I checked out the wiers and you where right it had a broken wire so I fixed it and guss what it workes thanks for the help
Old Jun 4, 2006 | 09:04 PM
good job
First off i want to tank you for letting us know the fix.........I just wished everyone would do that ,,,
secondly that's what i like to see ,, another car fixed,, another happy member
Race4Honda
Aug 2, 2014 01:53 AM
carson107
Aug 15, 2012 07:09 PM
bluemagic03
Nov 29, 2008 09:43 PM
darrell_amio
Nov 3, 2007 05:10 AM
Aistisval
May 20, 2007 05:00 PM
