DEA, Anchor, or Beck/Arnley Mount?
So I need a replacement rear motor mount for my Accord. Common issue but a PIA to replace.
The factory mount (#50810-SV4-J82) is $230 through an online Honda factory parts dealership which is not going to happen right now. I was going to order a DEA or Anchor mount since they look the same but... I've read reviews that the replacement mounts will not hold vacuum. I've also read very mixed things about hydraulic mounts from DEA and Anchor on other forums.
The Beck/Arnley one is $82 on Amazon which seems like a more ideal option. I've mixed feelings about BA though as sometimes the quality is good and sometimes it isn't. A lot of times I feel like I'm overpaying. Most of these companies seem to repackage or supply from others anyway.
Anyone want to chime in here on motor, engine, trans mount experiences? Which mount would last longer and be least likely to fail or have problems? Do you think the Beck/Arnley is best and I should avoid the DEA and Anchor mounts?
I have read posts of those w/ aftermarket mounts complaining of too much vibration transmitted by mount. For this reason I bought a used mount and installed. Problem turned out to be CV axle and not mount. They are available on ebay and local salvage yards. Inspect carefully for sound rubber and vacuum actuator works (pull oral vacuum and check).
jkowtko
12-20-2013 05:29 PM
baer77
02-27-2009 03:47 PM
