DEA, Anchor, or Beck/Arnley Mount?
Old Dec 15, 2014 | 08:48 PM
slickgeek's Avatar
Question DEA, Anchor, or Beck/Arnley Mount?
So I need a replacement rear motor mount for my Accord. Common issue but a PIA to replace.
The factory mount (#50810-SV4-J82) is $230 through an online Honda factory parts dealership which is not going to happen right now. I was going to order a DEA or Anchor mount since they look the same but... I've read reviews that the replacement mounts will not hold vacuum. I've also read very mixed things about hydraulic mounts from DEA and Anchor on other forums.
The Beck/Arnley one is $82 on Amazon which seems like a more ideal option. I've mixed feelings about BA though as sometimes the quality is good and sometimes it isn't. A lot of times I feel like I'm overpaying. Most of these companies seem to repackage or supply from others anyway.
Anyone want to chime in here on motor, engine, trans mount experiences? Which mount would last longer and be least likely to fail or have problems? Do you think the Beck/Arnley is best and I should avoid the DEA and Anchor mounts?
Old Dec 16, 2014 | 08:49 AM
I have read posts of those w/ aftermarket mounts complaining of too much vibration transmitted by mount. For this reason I bought a used mount and installed. Problem turned out to be CV axle and not mount. They are available on ebay and local salvage yards. Inspect carefully for sound rubber and vacuum actuator works (pull oral vacuum and check).
Old Dec 19, 2014 | 09:50 PM
slickgeek's Avatar
So you got your mounts used texashonda?
Old Dec 20, 2014 | 09:30 AM
Yes and it has worked fine.
Old Dec 21, 2014 | 12:36 PM
slickgeek's Avatar
Considering how hard the rear mount is to replace I'm definitely not going to spend time going to a junkyard getting one.
EXV6NIGHTHAWK
Jul 20, 2014 09:54 AM
jkowtko
Dec 20, 2013 05:29 PM
baer77
Feb 27, 2009 03:47 PM
oufy
Nov 5, 2006 09:50 AM
MECPcertified
Nov 18, 2005 02:12 PM
