Sponsored by:
Sponsored by:
Gear Shift lights/lamps
Old 05-23-2011, 05:25 PM
ownaccord's Avatar
Default Gear Shift lights/lamps
It looks as though the gear shift panel is not lighting up (not the one on the dash the one around the shifter)
It also appears that although the passenger heat warmer seat switch is backlit , the drivers side one is not. However both seam to be working and both indicators (dots) come on when engaged.
is this the same problem? is this a fuse or lamp or electrical issue?
thanks.
Old 05-23-2011, 06:59 PM
It is unlikely that all the shift position indicator lights on the console would fail simultaneously, so a common fault is suggested. Looking a wiring diagram the ground wire is only common fault. You will need to remove the console and find the black ground wire G101. You may need a Honda Shop Manual to locate the ground, however it should not be far from the console.
It is not clear from transmission range switch, but I suspect that shift position lights are led's and may not be replaceable.
Old 05-23-2011, 10:15 PM
ownaccord's Avatar
thanks. could the ground be the same reason the heat warmer switch is not backlit, but the other one is??
Old 05-24-2011, 02:31 AM
It could be as simple as a loose bulb or burned out bulb. Your accord has the same switches as my TSX and my passenger switch has a problem with the back light bulb. Also the VSA switch. I haven't had time to inspect.
Old 05-24-2011, 07:34 AM
ownaccord's Avatar
interesting, yeah bulbs are usually simple. having to take apart the centre console to replace one is kind of a pain
thanks.
Old 03-21-2012, 03:57 PM
Default What kind of bulb and where to buy
I need a replacement bulb for my 05 Accord gear shift, all I have to go on is S14V 1.4W
I have done internet searches and called a few places. Where can I get a bulb?
Old 03-21-2012, 06:46 PM
You may be able to find a match at the autoparts store. I think that I found one that matches that description. Yours is 14V and 1.4W.
The Honda OEM number is 54070-SDC-A81. You can get one at the dealership.
Old 10-02-2016, 05:43 PM
Default Easy to Replace SI bulb
Having installed aux cable recently, had the trim removal tool and knowledge. 3 steps. 1-Remove shift **** (pay close attention to position of internal plunger) w/ 2 screws. 2-Use trim removal tool to pry up console piece over shifter (then un-plug seat heater switches). 3-Remove black shifter cover by carefully prying open 4 tabs in in each corner (lift while prying). Now you'll see the bulb and socket. Twist the socket 1/4 turn, then slide toward drivers seat. Repeat to re-install.
O'Reilly stocks (or can get in a day) oem bulb ($3 for 10?). I wanted brighter, so ordered brightest LED from superbrightleds.com https://www.superbrightleds.com/vehi...1403&year=2006 . Also added HD foil to bottom of illuminator cup to increase reflection. I was told LED's can be +/- specific, so be sure to check that bulb comes on before re-installing trim pieces (insert bulb, turn key to on position, turn on headlights & replace shifter ****/shift to reverse [doesn't come on in park]). If bulb doesn't light, pull it out of socket, rotate 180 degrees, then re-insert.
letsclique
06-18-2016 04:29 PM
ekg98
12-20-2013 10:20 AM
d0n
02-04-2013 08:45 AM
RobinsonRicer
11-13-2012 06:16 PM
morgan2us
08-29-2012 05:53 PM
Quick Reply: Gear Shift lights/lamps
