How do I refill my abs
I just got a 5spd accord ex and the abs light is on. There's a bottle on the front of the car that says use dot 3 or 4 brake fluid but it also says that its preassured abd I cant find a way to fill it. Can anyone help thanks.
RE: How do I refill my abs
towards the firewall on the drivers side there should be a little container on top of the brake master cylinder, that cap usually just requires you to push down a bit and then twist it off and fill in there up to the appropriate line
There should be a grey colored rubber cap on the top of the ABS reservoir, under it remove the plastic strainer, then get a tiny funnel. Brake fluid will destroy paint, so if you spill any spray it off with some brake clean.
While you are under the hood, look for the sticker that might tell you WHAT YEAR the car is.
93Accord2.2
11-07-2013 07:10 AM
Max Utility
04-16-2012 04:47 PM
