How do I refill my abs
Old Dec 21, 2006 | 07:07 PM
miami honda's Avatar
Default How do I refill my abs
I just got a 5spd accord ex and the abs light is on. There's a bottle on the front of the car that says use dot 3 or 4 brake fluid but it also says that its preassured abd I cant find a way to fill it. Can anyone help thanks.
Old Dec 21, 2006 | 07:12 PM
sir_nasty's Avatar
Default RE: How do I refill my abs
towards the firewall on the drivers side there should be a little container on top of the brake master cylinder, that cap usually just requires you to push down a bit and then twist it off and fill in there up to the appropriate line
Old Dec 21, 2006 | 07:18 PM
hondadude's Avatar
There should be a grey colored rubber cap on the top of the ABS reservoir, under it remove the plastic strainer, then get a tiny funnel. Brake fluid will destroy paint, so if you spill any spray it off with some brake clean.
While you are under the hood, look for the sticker that might tell you WHAT YEAR the car is.
Old Dec 21, 2006 | 07:35 PM
hey you guys are awesome thanks for the replies.
[align=left] [/align]
Old Dec 22, 2006 | 03:32 PM
s20700134's Avatar
Just don't drop the little top with the o-ring on it under the winshield washer fluid tank. Its gonna be a PITA to get out. It will add about an extra 40 min to the abs fill. GOD LUCK
93Accord2.2
Nov 7, 2013 07:10 AM
kevin1517
Sep 6, 2012 08:15 PM
Max Utility
Apr 16, 2012 04:47 PM
jroxz44
Apr 9, 2012 11:18 PM
shinobi16
May 18, 2005 08:21 AM
