Sponsored by:
Sponsored by:
Changing Transmission Fluid
Old 06-20-2009, 09:51 PM
dgp1961's Avatar
Almost A Senior Member
Default Changing Transmission Fluid
Does the 2009 Accord (EXL V6) have a Transmission fluid drain plug similar to an oil change? If so is it easy to change? Is it just a matter of draining and re-filling? I've read in some threads it should be done twice to be sure the maximum amount of dirty fluid is being drained.
Old 06-22-2009, 07:54 AM
It should have one. If you drain/fill before it has a chance to get dirty, then you probably don't need to repeat. Auto tranny torque converter doesn't drain, so you only drain about 1/3 of the fluid. Repeating the process is important IF the fluid is dirty.
Old 06-22-2009, 08:00 PM
dgp1961's Avatar
Thank you Jim.
nyaccodguy
03-17-2015 06:38 PM
JMac
05-03-2012 09:53 AM
bjr001
04-27-2011 06:46 PM
doat
08-23-2009 10:45 AM
HondaAficionado
06-09-2009 11:46 PM
Quick Reply: Changing Transmission Fluid
