Sponsored by:
Sponsored by:
Start up squeal that goes away...
Old 08-15-2010, 09:41 PM
bigdawg74's Avatar
Default Start up squeal that goes away...
Just recently my '91 Accord has been squealing when I start it up for about 3 minutes or so. Usually gone after heading down the road for a mile or so. Both belts look good. Thoughts??
Old 08-15-2010, 09:54 PM
Try belt dressing. Not a permanent solution, but if it works then you know the source of the sound.
Old belts get hard & slippery with age. If you over-tighten them to stop the slipping, then next you'll be asking how to replace alternator bearings.
Old 08-16-2010, 01:17 AM
kris_loehr's Avatar
A bar of soap also wills temporality stop the s squealing to determine if it is one of the belts. Just let the belt cut into the soap when running.
Old 08-16-2010, 07:29 AM
Good idea, as long as you don't get your fingers into the spinning belt. Spraying water might work too, just to change the sound & prove to yourself that it's the external belts.
Old 08-16-2010, 08:08 AM
bigdawg74's Avatar
I'm guessing you want the soap to be on the underneath (grooved) side of the belt?
Old 08-16-2010, 11:29 AM
kris_loehr's Avatar
Yes you want to get the bottom
nufftalon
09-23-2014 01:21 AM
will93
03-17-2008 07:21 PM
91boz
01-01-2007 12:39 AM
ckebottle
09-23-2006 09:35 PM
Quick Reply: Start up squeal that goes away...
