battery charger put on wrong, what damage can I expect
Old Oct 25, 2009 | 09:23 PM
jddavis16
Default battery charger put on wrong, what damage can I expect
I bought a 95 accord 4dr for my daughter. Car didn't want to start, jump started it and drove it a while thinking that would recharge the battery. Car would not crank so I jump started it again and brought it home. Put an old battery charger on it. Clamps have long ago lost the colored plastic and I inadvertinatly crossed polarity. Now when I turn the key on I do not get any lights such as alt, etc. The light in the door does light when the door is opened. What damage may I have done? Help. Thanks
Jim Davis
Old Oct 25, 2009 | 10:57 PM
First things first, check the battery fuse in the engine bay fuse box. I think it's 100 amps or something. Make sure all the main fuses are not blown and replace any fuses that are blown. Then try to crank it.
Old Oct 26, 2009 | 09:22 AM
Try swapping in a different battery. Got any battery? If it doesn't fit the tray, just hook up the cables (the right way, please). Cross your fingers; it's possible you damaged the battery & not the car.
Old Oct 26, 2009 | 05:21 PM
Exclamation Use Caution
You more than likely cross polorized that battery and will have to get a new one..Take it to Auto Zone and have it checked out 1st before you do anything else to the car...
Old Oct 27, 2009 | 09:57 PM
jddavis16
I checked all the fuses and they were ok. Then I jump started it, noticing that all the lite cluster lit up before I cranked it up. Took the battery out and took it to Auto Zone and it tested defective. New battery installed and everything seems to be working. Odd tho, after replacing the battery, I did not have to key in the anti theft code into the radio. Thanks for the input. I was afraid that I may have wiped out the computer.
Old Oct 28, 2009 | 09:25 AM
Originally Posted by jddavis16
... I was afraid that I may have wiped out the computer.
Well, that CAN happen when you reverse the battery. Good thing it didn't happen this time.
Old Oct 28, 2009 | 12:33 PM
Talking Right On Member
Your Welcome Sir:
All us folks in here are more than Happy to help a member out..you do the same some day for one of us...
carid
Dec 5, 2014 03:01 AM
Tony1M
Mar 7, 2009 08:00 PM
isenegger
Jan 23, 2008 05:43 AM
Erinsaccord
Sep 6, 2007 11:10 AM
SuPaSuNz21
Nov 28, 2005 03:09 PM
