AC compressor not starting
Old Aug 31, 2010 | 02:02 PM
dmoak's Avatar
Default AC compressor not starting
I recently replaced the AC compressor in my 03 EX V6. It worked great for a while, but now the compressor will not start when I turn the AC on. I know the clutch/compressor work becuase I hooked up a jumper wire from the battery, and the compressor engaged and the air got cool.
I checked the AC relay and it seems to be fine. The refrigerant pressure is right where it should be. What could be causing the compressor not to switch on?
Old Aug 31, 2010 | 06:37 PM
I just made a new thread in the DIY section called HVAC error codes. Check for any HVAC error code(s) and post them on here.
Old Aug 31, 2010 | 07:37 PM
dmoak's Avatar
Is there a way to retrieve the HVAC codes without a scan tool?
Old Sep 1, 2010 | 05:52 PM
twilliamsen's Avatar
Osmosis... Just kidding... go to autozone and have them pull the code.
Old Sep 1, 2010 | 07:33 PM
How did you test the relay ?? under hood fuse box chk fuse # 12 7.5 amps, under dash box chk # 30 , 7.5 amps ( key on, )
if fuses are ok,, pull the relay out, you should have power on 2 cavities, ground at 1 and nothing in 1 ..
if you have power and ground ,,,, jump a wire from 1 of the power cavities to the cavity that has nothing ,,,,,,,,,if compr turns on,, you got a bad relay
let us know..
Old Sep 1, 2010 | 09:39 PM
Yeah, there is. Go to the DIY section & look for PA's post entitled "HVAC error codes". Do what it says.
ak474u
May 4, 2015 11:15 PM
auto_troubleshooters
May 31, 2012 09:24 PM
BonnieO
Jun 3, 2008 02:16 AM
Pauls95
Apr 7, 2008 01:45 PM
Lew
Jun 23, 2007 11:20 AM
