A/C compressor clutch not engaging
Old Aug 27, 2007 | 07:55 AM
auto_troubleshooters
Default A/C compressor clutch not engaging
I was driving back from savanah and i pulled into a gas station and the compressor just quit working all together but i still have power to all points. Is there something wromg with the compressor clutch?
Old Aug 27, 2007 | 08:12 AM
deserthonda's Avatar
Default RE: A/C compressor clutch not engaging
this is the second post you have opened with the same question (8-23) did you go back to the original and read what i wrote ????
And please keep from opening up more than 1 post with same question it will take unnecessary space
thank you..
Also go to the top of.,... general tech help,,, and read the post,,,,,,,,Members please read before posting ..
Old Aug 28, 2007 | 07:18 AM
Sorry for being in a hurry. Its a 2003 Accord LX 2.4 litre automatic. I have checked the technical service bulletins and followed their directions. I have power to all points but the compressor clutch still isn't engaging. You can turn theclutch by hand.
Old Aug 30, 2007 | 03:56 PM
wietgr's Avatar
Low charge?
Old Aug 30, 2007 | 06:01 PM
if you got power at the lt blue wire at compressor coil,, it is either clutch gap too wide or possible faulty coil,,
Old May 30, 2012 | 10:31 PM
jayjppatel's Avatar
Default 2003 aCCORD a/c cLUCH
I have 14v at blue wire but cluch is not engaging
Old May 31, 2012 | 08:59 PM
Sorry but we are going to need a ton more than that.....and the same thing Desert said to the first poster applies....I read oldest to newest so please don't tell me I see this same from you again.....If not, you can start a new thread with the things you have done, tested (details) and that.
Old May 31, 2012 | 09:03 PM
crispin's Avatar
You want us to help you but 11 words is all you can type to describe your problem?
Start a new thread, explain your situation, car, what you have tested, ect.
or take it to a dealer and tell them that you "have 14v at the blue wire but clutch is not engaging" and let them charge you to repair it.
Old May 31, 2012 | 09:24 PM
Dr. Drivability's Avatar
good cop time ...i had a similar issue. if the system was cooling fine and then just quit working and the clutch is not engaging, the clutch coil is burned out...short of a catastrophic refrigerant loss of course.
i replaced the clutch and coil together, these compressor are very reliable aside from this issue. original setup lasted 160k miles. still cooling to 40 degrees at the vent.
Mario Locatelli
Feb 9, 2014 08:31 PM
foxies
Dec 23, 2010 05:31 PM
96accordguy
DIY Answers.
Jul 30, 2010 02:27 PM
dptucunduva
Aug 5, 2007 02:44 PM
southnash
Jul 3, 2007 10:49 PM
