Brake light,spoiler light erratic.
Old May 31, 2012 | 09:08 PM
fakebrake's Avatar
Default Brake light,spoiler light erratic.
Well i have had pretty good luck with my new old accord so far. Using faq's i diagnosed and fixed the oil leak. Oil sending unit and have the ac working. Now i have one problem left to get an inspection sticker. When i bought the car the drivers side brake light on the trunk did not work. I changed the bulb and nothing. Everything looks good so i wiggled around some wires to various plugs on that side in the trunk lid and i got that light and the spoiler led's to work.
Now the problem is that sometimes they work and sometimes they dont. I can have someone hold the brake down and mess with them and nothing. I will give up and have them push the brake to confirm its broke and all work. Any common problem i should be looking for.
Thanks in advance. 1993 accord ex.
Fakebrake.
Old May 31, 2012 | 09:12 PM
crispin's Avatar
corrosion in the connector?
Old May 31, 2012 | 09:25 PM
Follow the black wire from the bulb. It should ground near the driver's tail light in the trunk. Unbolt that wire, clean the eyelet and bolt with sandpaper or a wire brush, then bolt it back down.
thaison86
Jun 28, 2012 12:03 AM
MikeT
Jul 18, 2011 04:17 PM
WaldoPepper
May 21, 2010 01:01 PM
johnk
Dec 18, 2007 11:57 PM
jimmyznutz
Jan 19, 2007 02:04 AM
