aftermarket projectors "black spots" help
Old 05-01-2007, 09:53 PM
noboundaries6289's Avatar
Default aftermarket projectors "black spots" help
hey all, I've had aftermarket projectors from APC installed since last christmas. Since then, a light black circle has developed in the center of the projector lens (inside the housing). It is only visable when the lamps are on. Do I just let it all "black out" and if I do, will it effect visability of headlamps? I'm running sylvania silverstar premium bulbs for low beams and ultra for high. Nothing is wrong with high beams just low. any suggestions?
ps. headlamp removal is out of the question, took around 6hrs to install projectors. And that was at a shop!
Old 05-01-2007, 10:40 PM
Default RE: aftermarket projectors "black spots" help
6 hours!!!! Was a monkey doing it?
IS the black spot causing the light beam to disperse as well?
Old 05-01-2007, 10:59 PM
were those projectors retrofitted
Old 05-01-2007, 11:29 PM
the black spot seems to not have an effect on the lighting yet. Also, by retrofit do you mean "rigged up". They were supposed to be direct replacements. No rewiring at all.
Old 05-02-2007, 12:35 AM
03Sleeper's Avatar
so they were plug and play?
interesting....how much did you pay for your projectors?
Old 05-02-2007, 01:46 PM
They are plug and play, I also got them for christmas. If I had to price them out on ebay there is a set just like mine going for 64.99.
here's a link to them, they look identicle to mine.
http://cgi.ebay.com/ebaymotors/94-97...11548573QQrdZ1
I don't know if these are APC or not. mine are stamped, that's how I know.
Old 05-02-2007, 02:01 PM
my guess is that it's burning the plastic
Old 05-02-2007, 07:14 PM
Fenix's Avatar
thats what i would guess too, do you often drive with your high beams on? Also 6 Hours? sounds like you got hosed. I did my own projectors that were plug and play and it barely took an hour and i did them myself
Old 05-03-2007, 02:59 PM
believe it or not, I was with the mechanic the whole time. I watched as he worked. Also, the high beams are fine, just low beams seem to be messed up. The low beams are the only ones in the projector housing.
Paul Antonio Davis
10-15-2014 06:17 PM
stellaj908
02-07-2013 10:30 PM
mukman22
03-18-2008 08:47 PM
benjiaccord
11-17-2006 11:40 PM
Accord98Retro
05-05-2006 01:23 PM
Quick Reply: aftermarket projectors "black spots" help
