aftermarket projectors "black spots" help
Old May 1, 2007 | 09:53 PM
noboundaries6289's Avatar
Default aftermarket projectors "black spots" help
hey all, I've had aftermarket projectors from APC installed since last christmas. Since then, a light black circle has developed in the center of the projector lens (inside the housing). It is only visable when the lamps are on. Do I just let it all "black out" and if I do, will it effect visability of headlamps? I'm running sylvania silverstar premium bulbs for low beams and ultra for high. Nothing is wrong with high beams just low. any suggestions?
ps. headlamp removal is out of the question, took around 6hrs to install projectors. And that was at a shop!
Old May 1, 2007 | 10:40 PM
Shadow1992's Avatar
Default RE: aftermarket projectors "black spots" help
6 hours!!!! Was a monkey doing it?
IS the black spot causing the light beam to disperse as well?
Old May 1, 2007 | 10:59 PM
2002haccord's Avatar
were those projectors retrofitted
Old May 1, 2007 | 11:29 PM
the black spot seems to not have an effect on the lighting yet. Also, by retrofit do you mean "rigged up". They were supposed to be direct replacements. No rewiring at all.
Old May 2, 2007 | 12:35 AM
03Sleeper's Avatar
so they were plug and play?
interesting....how much did you pay for your projectors?
Old May 2, 2007 | 01:46 PM
They are plug and play, I also got them for christmas. If I had to price them out on ebay there is a set just like mine going for 64.99.
here's a link to them, they look identicle to mine.
http://cgi.ebay.com/ebaymotors/94-97...11548573QQrdZ1
I don't know if these are APC or not. mine are stamped, that's how I know.
Old May 2, 2007 | 02:01 PM
CoryTheStory's Avatar
my guess is that it's burning the plastic
Old May 2, 2007 | 07:14 PM
Fenix's Avatar
thats what i would guess too, do you often drive with your high beams on? Also 6 Hours? sounds like you got hosed. I did my own projectors that were plug and play and it barely took an hour and i did them myself
Old May 3, 2007 | 02:59 PM
believe it or not, I was with the mechanic the whole time. I watched as he worked. Also, the high beams are fine, just low beams seem to be messed up. The low beams are the only ones in the projector housing.
Paul Antonio Davis
Oct 15, 2014 06:17 PM
stellaj908
Feb 7, 2013 10:30 PM
mukman22
Mar 18, 2008 08:47 PM
benjiaccord
Nov 17, 2006 11:40 PM
Accord98Retro
May 5, 2006 01:23 PM
