2008 honda accord coupe HID light question!
Old Nov 24, 2008 | 12:02 AM
bananazx's Avatar
Default RE: 2008 honda accord coupe HID light question!
ORIGINAL: falkore24
The relay has nothing to do with when you turn the lights on because if they turn off when you crank the engine, this won't change.
If you start engine with light on, the starter motor drains electric and the balaster may not have enough electric. That's why one side of my HID kept turned off when I crank the engine. When engine is starting, voltage goes low enough to turn the bulb off but not completely disconnected. It does not light up until you turn it off and on again. So I installed relay which directly connects from the battery to the bulb to give direct supply of electricity and therefore prevent the supplied voltage to the balaster from going low.
With 35w HIDs, I've never had any problem like this, but with 55w HID, it happens.
Winston Hart
Sep 7, 2013 12:32 PM
An D. Nguyen
Aug 13, 2013 09:59 PM
sunshinejenn03
Apr 27, 2010 08:46 PM
illtl
Sep 3, 2009 06:38 PM
attache16g
Aug 26, 2008 08:46 AM
