Anyone Know How To Black Out The Reverse Lights On a 2005 Coupe?
Old May 23, 2010 | 05:45 PM
pbplayer257's Avatar
Default Anyone Know How To Black Out The Reverse Lights On a 2005 Coupe?
Does anyone know how to this? I don't know if they just put a piece of black film or changed the actual light.
Uploaded with ImageShack.us YOUR CAR LOOKS NICE AND SHINEY...WHEELBROKERANG
Old May 23, 2010 | 09:21 PM
corvetteking's Avatar
VHT Nightshades is a translucent spray used for blacking out plastic... Do a good tape job, and you can do as many coats as you want, untill you get the desired tint... Heres a pic of my tails on my cutty
Old May 23, 2010 | 09:23 PM
heres before the nightshades.Name:  7935_134977862623_667382623_2976228.jpg
Old May 24, 2010 | 02:34 PM
oh nice, can you remove it?
Old May 24, 2010 | 09:48 PM
19Accord97
Usually you have to request it to be ordered and Advanced Auto or whatnot.
Most people just spray the Niteshades, but I always put a UV resistant clear coat over it. Removal would require sanding.
Old May 29, 2010 | 04:43 PM
Orielleys auto parts always has it in. In the paint section. The UV resistant clear coat is a good idea, but not necessary
The stuff is removable. I had to take mine off of that oldsmobile up top the first time I did it, because it was too dark and I got pulled over. Then I re-did it as pictured up top... My suggestion is to not do more than 3 solid coats. The cop said you have to be able to see the light(light up) at 500 feet. Which mine was, cop was just a hater...lol
Old May 29, 2010 | 05:24 PM
xavier03's Avatar
very easy check out mine... simply use a sandpaper and give some tainted clearcoats
Old May 30, 2010 | 05:30 PM
i think i'm just going to use film
Old May 31, 2010 | 07:02 AM
chip's Avatar
Any bodyshop can do it for you pretty cheap.
Old May 31, 2010 | 11:13 PM
Exclamation Hi Member
Wont tell you from me cause I think that you are going to be just looking for a ticket and maybe get your car confiscated...
pls click the image 3 times
Attached Thumbnails Anyone Know How To Black Out The Reverse Lights On a 2005 Coupe?-sdd_f35testa_095.jpg
