Black out trim...???
Old Jul 14, 2010 | 11:07 PM
vengeance's Avatar
should have used adhesion promoter first since you went with the spray paint. you can always sand it off and redo it. i take it you didn't scuff it up the slightest bit did you?
Old Jul 15, 2010 | 08:03 AM
dunnskii's Avatar
thanx for the reply. Yes I did "scuff" it up...actually the way i did do it was to 1st i cleaned the areas with soap and water,taped off, using fine sand paper sanded a bit till all the surface was even, and also between coats, then cleaned again w/ alchol and water spay, 50/50 mix, then painted it w/Krylon spray paint. Did it several days ago and it seems to look good, if i have probs ill redo... think its all ok, i guess only time will tell
wdick6210
Sep 15, 2011 11:40 AM
ChicagoBob123
Oct 18, 2010 11:57 AM
pbplayer257
Jul 20, 2010 08:26 PM
vr4
May 28, 2008 12:58 AM
