Fog Light install
Old Jun 8, 2007 | 11:26 AM
ducatiff's Avatar
Default Fog Light install
Has anyone installed fog lights on a 03-06 coupe? I don't like the way that the front end looks and see tons of aftermarket OEM style lights on Ebay. I was just wondering if anyone had put any of these on and how was the installation.
Old Jun 18, 2007 | 11:23 AM
ducatiff's Avatar
Default RE: Fog Light install
Nobody has added any fogs???
Old Jun 18, 2007 | 02:37 PM
jipmpizzle's Avatar
I tried to install the OEM ebay ones on my 05...they didnt work but it was something I did because I took it to the dealer because I thought they could easily make them work but they said I had a constant current running through my car (WHEN IT WAS OFF WITH THE KEY OUT)..they wanted to fix it but it would cost regular labor ($360) for them to go over what I did and find the problem...so I said f**k that and I yanked everything out and just left the fogs in...so I pretty much have the fogs in just for appearance
Old Jun 22, 2007 | 02:51 PM
rob3201's Avatar
If your handy, the install is easy and the directions are clear and precise. If your not handy, let the pros do it. Buy OEM, they last longer and fit great.
Old Aug 22, 2007 | 04:42 PM
ochondakidd
I have bought oem fog lights off of ebay for my 04 accord and they look great. I used only the wiring that hooked up to the backside of the fog lights and then i cut the right after that and ran my own and used my own switch in the car. The wiring harness that came with mine were not long enough to run. The only down fall with running your own wiring is that then you dont have the relay switches and and when you turn the car off and leave the foggies on there is no beeping or buzzing like if you left your headlights on or if you left your key in the ignition and opened the door.Oh and also they did not come withall the screws and washers i needed so i had to use my own for the missing ones.Other than they they look and work awsome and i am glad i got them.
AccordianPlayer
Oct 16, 2012 12:01 PM
05blkaccord
Sep 30, 2012 09:21 AM
kuthedude
Jun 24, 2010 10:14 AM
AFTricker
Dec 31, 2009 05:25 PM
Josh2002SiR
Jun 22, 2009 03:04 PM
