Foglights??
Old Dec 21, 2009 | 05:53 PM
ebarrera661's Avatar
Almost A Senior Member
Default Foglights??
How do I even wire them. They are just the fog lights with two wires out of both of them. I want them to turn on with my corner lights, so were would I hook them up?
-Thanks
Old Dec 29, 2009 | 07:47 AM
AccordinPA's Avatar
I wired mine to just run off of a switch so I can't really say exactly what you need to do. I think that you need a relay switch, and run them into your fuse box somehow to have them hooked into your headlights.
Old Dec 29, 2009 | 12:17 PM
keep_hope_alive's Avatar
you could do it several ways. if it were me, i'd tap the corner light wire, and wire it to a relay coil (you don't want to add the load of the fog lights to the corner light wiring). then get power from the battery or fuse box with a fused wire (12 AWG with 20A inline fuse).
Then you can decide if you want manual override control at the dash. in which case you would run a 2-3 wires from the relay into the cabin, to a toggle switch (lit or not). then decide if you want to override on, override off, or both and wire the toggle appropriately.
most fog lights should come with wiring instructions, but the above is safe and effective.
Old Dec 29, 2009 | 01:08 PM
Talking Hello Member
You have a wealth of great information in this post-so Im going to leave it in here...Normally I take out almost all post's that have direct links to other site But I feel that this post of your is very worth-while.
Please make sure that you dont post any direct links to other selling site..because I do stick by RULE # 7 of the HAF .
Thank You-WheelBrokerAng
Kool Kid
Dec 1, 2007 09:46 AM
Kool Kid
Nov 29, 2007 09:19 AM
t00fatt
Aug 9, 2007 10:34 AM
cheggie
Mar 20, 2007 06:18 PM
o4vroom
Jun 3, 2006 12:30 AM
