2006 accord head light question (fairly stupid)
Old Dec 22, 2009 | 12:04 AM
mgamer20o0's Avatar
Default 2006 accord head light question (fairly stupid)
ok its a fairly stupid question but.... my head light burnt out went to replace it and it just wont come out.
will loosing those two screwed help me release the bulb so i can change it out? i did the other side fine this side just wont budge.
Old Dec 22, 2009 | 01:05 AM
Arrow Try It
Give it a try with the screws, I honestly have changed over 400 hundred sets of headlights and have never come across a set that wouldnt come out...
Attached Thumbnails 2006 accord head light question (fairly stupid)-thumb_obama%2520gave%2520me%2520change.jpg
Old Dec 22, 2009 | 10:43 AM
Briggz's Avatar
Almost A Senior Member
Changing bulbs on my 7th gen is a PITA... After you take out the screws, you have to turn the whole bulb/plug a little bit (I think counterclockwise). This sounds easy... but the first time I tried doing it, I thought I was going to break something, I had to pry at it so hard. It might give you resistance, but as long as all 3 screws are out, and you turn in the right direction, it'll come out.
Old Dec 31, 2009 | 12:17 AM
ohhtu
don't unscrew anything. just press down on the white tab at the bottom of the plug. unplug it from the light bulb. it's a little tough to take out but, keep trying. after the white plug is removed, turn the bulb and it should come loose.
Old Jan 1, 2010 | 01:45 PM
finch13's Avatar
Normally you do don't have to remove those screws, but if the bulbs won't twist you could remove them and pry it straight out. Those screws are only there as retainers for the tabs on the bulb base.
kwakers
Aug 19, 2015 05:48 PM
bsdubois
Nov 24, 2013 11:46 PM
buzzbee88
May 14, 2012 12:19 AM
bustum
Jul 31, 2010 04:16 PM
Wildcat
Feb 10, 2006 02:45 PM
