Highest Kalven without kit?
Old Jan 28, 2008 | 06:54 AM
Yorty's Avatar
Default Highest Kalven without kit?
Can you get a high kelvin bulb, or is over like 5000k require you to install a new conversion kit. I searched around and couldent find any topics already started on how high a bulb can go kelvin without any install or kit.
Old Jan 28, 2008 | 07:22 AM
BlkCurrantKord's Avatar
Default RE: Highest Kalven without kit?
Its kelvin, and you can buy bulbs that give the appearance of up to like 8000k. I have 6000k bulbs in mine. Ideally 4300k is the best.
Old Jan 28, 2008 | 07:27 AM
Yorty's Avatar
Yea sorry wrote from my phone, was in class. The 8000k can actualy produce enouf power?
Old Jan 28, 2008 | 09:11 AM
ORIGINAL: Yorty
Hi Yorty..was that a question up above or were you giving us an answer to your own question [sm=smiley25.gif]
Old Jan 28, 2008 | 10:24 AM
ORIGINAL: Yorty
The lower the number, the whiter to yellower it becomes.
4300k is almost pure white or close...the higher it gets the more purple/blue it becomes and actually emits less white light. Anything under 4300k would be good as a fog light.
Old Jan 29, 2008 | 07:23 AM
AccordEXxx's Avatar
If your talking about halogen bulbs than be prepared to lose your visability! Ive read the best after market ones htat are actually bright would be the silverstar ultras. Most of the other bulbs will look cool but they will decrease your light output. I conpared the stock 9006 bulb on one side and on the other i used a 9005 bulb (mod) and the stock ones were WAY brighter. hoped this helped
Old Jan 29, 2008 | 02:08 PM
falkore24's Avatar
Kelvin on a light bulb is the COLOR temperature. It has nothing to do with HEAT temperature, therefore if you can find it, you can use whatever ####(#)deg K bulb that you want. As noted above, the closer to white that you get, the more efficient the bulb will be at producing light from the same input power (55 Watts for stock 9006). Feel free to search Wikipedia for more info on this topic ..... or HAF also since this has been covered extensively numerous times.
Old Jan 29, 2008 | 02:13 PM
falkore24's Avatar
ORIGINAL: AccordEXxx
9005 is a 65 Watt highbeam. 9006 is a 55 Watt lowbeam. The number represents the socket; nothing else. If you really did stuff 9005's into your lowbeam fixtures, you either irreversibly modified the plug or cut it off. I highly reccommend that this is not done. If you want more wattage, get a relay kit and high wattage bulbs. Before my projectors, I had 80 Watt 9006 lowbeams and 100W 9005 highbeams. They were definately brighter than OEM, silverstars, PIAA's (OEM Wattage) or any other normal power bulbs.
Old Jan 29, 2008 | 05:05 PM
AccordEXxx's Avatar
ORIGINAL: falkore24
Yeah how long did it take for your harness to melt. The 9005 mod to fit in a 9006 socket is a mod many people do. It is a bit brighter than 9006's but you can barely tell the difference.
Old Jan 29, 2008 | 05:24 PM
falkore24's Avatar
Note the high power relay kit. Harnesses were fine because ceramic doesn't melt [sm=smiley20.gif]
The 9005 is brighter because it's normally 10 Watts more powerful. For less effort, just go for the full high wattage system that I had. It's not that expensive either..... maybe 50 bucks for the kit then new bulbs.
EDIT: Technically, the high power bulbs are legal for offroad and show use only ..... they are still lower profile than blue/purple HID's
93Accord2.2
Sep 1, 2013 03:14 PM
toyhonda
Jun 1, 2013 12:35 AM
JFK
Aug 9, 2005 11:23 AM
