How to change front signal light cover
Old May 10, 2006 | 05:07 PM
tle198
Default How to change front signal light cover
I have 1997 Honda Accord. The front signal light cover was broken. Is there any screw I need to open to take the cover off? I don't know how to access those screws. Could someone show me how to change the plastic light cover?
Thanks
Old May 10, 2006 | 08:53 PM
sir_nasty's Avatar
Default RE: How to change front signal light cover
if it's the cover I'm thinking of I believe it's a full sealed assembly... I.E. you can't just replace the cover you need to buy a new corner light.... they aren't very spendy... I would probably just find something on e-bay and if you have problems with condensation then drill a small hole in the lower corner...
Old May 11, 2006 | 12:27 PM
tle198
Thanks sir-nasty for your help. I did look on the web and found the part I need. You're right, it is a whole assembly. My question is can I use the screwdriver to pry it out so I can put the new one in?
Old May 11, 2006 | 06:28 PM
sir_nasty's Avatar
Here's the manual page for a 94 accord... unless you're talking about the corner lights this should be about the same
[IMG]local://upfiles/3079/2ED16383A3334CD2BDE2AC2B46E406C0.jpg[/IMG]
schaicho24
Jan 1, 2014 09:10 PM
Micro Schweitzer
Jan 18, 2011 09:21 PM
03Sleeper
Jun 11, 2008 08:54 PM
bmacb
Dec 28, 2007 10:09 AM
zelseman
Jan 8, 2006 04:19 AM
