How do I setup an Accessory fuse box?
Old May 13, 2008 | 02:26 PM
98CoupeW/Carbon
Default How do I setup an Accessory fuse box?
I am trying to wire the angel eye leds to a seperate switch. And I'd like to just setup an accessory fuse box for that and some other things. Where do I wire in the extra fuse box?? Directly to the battery or some other way??
Thanks
Old May 13, 2008 | 02:38 PM
falkore24's Avatar
Default RE: How do I setup an Accessory fuse box?
If I were you, I'd run a main-line to the battery, but through a high power relay that recieves a signal from the ignition switch. This way, the aux panel shuts off when the car is off. Your best bet is to salvage a fuse panel from the junk yard.
Old May 13, 2008 | 02:57 PM
klrspz's Avatar
pretty much what iw as gunna say.. i've often thought of implementing this in my ride, but i just don't have the time or effort to even mod any more lately.
Old May 14, 2008 | 01:07 PM
98CoupeW/Carbon
Ok sorry to sound like an idiot but can you give me some step by step instructions?
Old May 14, 2008 | 01:55 PM
falkore24's Avatar
Assuming that you are looking for directions on hooking up the relay, search for fog lights. I've done a few writeups on this topic. If I can find it, I'll let you know.
Old May 14, 2008 | 03:13 PM
98CoupeW/Carbon
Ok so I just bought a "Add a circuit" and was told on another forum that I can just pop that into a fuse and then hook it up to my led light circuit
Are there any issues I should be worried about by doing it this way??
Old May 14, 2008 | 04:46 PM
falkore24's Avatar
Adding a circuit doesn't do a thing for control. It just gives you a place to tap power.
Old May 15, 2008 | 02:05 PM
98CoupeW/Carbon
I have the add a circuit wired to the switch which is then going to be wired to the leds and the ground
Is there anything else I need to do??
tvandentop
Sep 17, 2011 06:42 AM
rmletc
Jan 5, 2010 05:59 PM
nafango2
Oct 5, 2007 08:32 PM
AustinGT
Apr 21, 2006 11:28 PM
IAAccord95
Oct 25, 2005 09:45 PM
