Accessory Power Outlet Fuse - 2004 Accord
Old Aug 1, 2009 | 03:17 PM
rmletc
Default Accessory Power Outlet Fuse - 2004 Accord
I cannot seem to find the accessory power outlet fuse. There is nothing listed anywhere in the manual or in the the fuse boxes for the accessory outlets. The radio still works, therefore its not hooked up to that, nor is anything else out. I have read that other hondas have it attached to the outlet itself.
Can someone confirm where it might be.
I have two outlets, one on the front console that says 10 amp fuse and one in the center console. Both are not working. If you know where it is please please guide me. If it is attached to the wire that connects to the outlet then which one? I assume the front one. How do I get it out off there? Do i need to remove any plastic console parts or can it be twisted out
2004 Accord two door automatic.
Thanks in advance..........
Old Jan 2, 2010 | 09:57 PM
JeffreyGC's Avatar
i am having the same problem, im gonna see if i can find a service manual, and i will let you know what i find, idk if there is any difference between my four door 06 accord and ur two door 04 accord, but its worth a shot
Old Jan 3, 2010 | 08:46 AM
rmletc
Please let us know because we haven't gotten any help from the dealerships short of "bring it it" for $100 per hour!
Old Jan 5, 2010 | 03:28 PM
JeffreyGC's Avatar
I havent gotten the book, but i found which fuse was the accesory fuse on my honda, fuse 9, it was the one by the drivers feet, mine was a 15 amp fuse but idk if thats it on urs,
on a side note, the dealer wouldn't tell anyone unless they brought it in, in fact im almost sure that some car manufactures make some things difficult, that way the dealer can fix it at significantly higher prices, case in point, the smart key,
Edit: if 9 isnt blown, try fuse 32, i read on a this on a different forum and i ll provide the link
http://www.driveaccord.net/forums/sh...ad.php?t=38680
Old Jan 5, 2010 | 04:08 PM
JeffB's Avatar
I have 2004 V6 but it should be the same. If you stand by, I'll check my Helm shop manual when I get home from work...in an hour or 2.
--Jeff
Old Jan 5, 2010 | 05:59 PM
JeffB's Avatar
According to the shop manual, the fuse for both the front and inside console sockets is #9 located in the driver's door fuse box. It is 15A. THe wires behind should be red/yellow.
Good luck.
--Jeff
odabiri
Oct 27, 2011 09:06 AM
kgsydow
Oct 1, 2008 10:32 AM
98CoupeW/Carbon
May 15, 2008 02:05 PM
loki
Jan 20, 2008 12:01 AM
dm128956
May 9, 2007 02:10 PM
