12v power outlet
Old Oct 1, 2008 | 10:24 AM
kgsydow
Default 12v power outlet
i bought a 2008 accord ex-l. i can't get over the fact that the cigarette lighter has no power when the ignition is off. what is the easiest way to modify this? do i need to go back to a chevy?
kevin
Old Oct 1, 2008 | 10:32 AM
falkore24's Avatar
Default RE: 12v power outlet
What do you need powered when the car is off??? This was done on most cars to reduce unintended power drains. If this bothers you enough, you can remove the stock power lead and run a new mainline from the battery. I suggest using an inline fuse if you do this, also 14ga. wire and a 25A max fuse size. If you want 30A, use 12ga. wire, but IDK what the lighter socket itself can take.
odabiri
Oct 27, 2011 09:06 AM
noob447
Apr 29, 2011 03:54 PM
DaveQ
Jun 19, 2009 07:00 AM
loki
Jan 20, 2008 12:01 AM
dm128956
May 9, 2007 02:10 PM
