How are my emblems attached?
Old Apr 24, 2007 | 11:05 PM
RTexasF's Avatar
Super Member
Default RE: How are my emblems attached?
Get some monofilament fishing line (heavy)and run it behind the emblem you wish to remove. If it goes a 1/4" and stops dead , regardless of your efforts to "saw" it off, then there's likely a pin. If it goes all the way through then it's just glue and the emblem will come off. As previously mentioned goof off or goo gone will remove the sticky which will need to be sealed or waxed once you are done. Pins through the metal will need to be filled and painted by a pro.
Old Apr 26, 2007 | 04:06 PM
gliff159's Avatar
goof off would not be somthing id recoment using on your car as it is a solvent. it will start to strip off the clear coat and the paint go with goo gone as it is more of a cleaner
Old Apr 27, 2007 | 03:35 AM
03Sleeper's Avatar
piano wire?
Old Apr 28, 2007 | 05:40 AM
HuYnHness's Avatar
yeah because everybody has spare piano wire lying around. im such a disgrace to the asian race i do not know how to play piano
drdavidge
Feb 19, 2012 07:56 PM
batch2
May 30, 2010 05:29 PM
brochuj
May 3, 2008 04:18 PM
PJ_STYLES_95AccordEx
Feb 12, 2008 10:33 AM
mark_m
Mar 27, 2007 09:48 PM
