light bulbs
Old Sep 14, 2007 | 08:50 AM
02BlueAccord's Avatar
Default light bulbs
ok i got these headlights alittle while ago and i want to know if i can go with a stronger light bulb then whats in them without burning a whole through the plastic. thanks http://cgi.ebay.com/ebaymotors/98-99...spagenameZWDVW
Old Sep 14, 2007 | 09:38 AM
HuYnHness's Avatar
Default RE: light bulbs
im pretty sure HID bulbs dont get too hot if you can put them in the projectors. and i dont think the plastic will melt that easily but dont take my word for it. just my assumptions.
Old Sep 14, 2007 | 10:08 AM
falkore24's Avatar
If you want to go with high wattage halogens, I wouldn't expect a problem with the housing, but you will want upgraded connectors. The higher wattage can melt the stock plugs. HID uses less wattage hence less heat. I think that the upgraded plug are ceramic, but I'm not sure. When I had over-wattage bulbs in the stock fixtures, I used a high power relay kit .... also a good idea for this method of lighting. HID is the best way to get more light, and I have a set in the TYC projectors .... no problems. If you get an HID kit, make sure that you get the correct one. My car had 9005/9006 headlights stock, but my TYC's use H1 bulbs so I have an H1 HID setup, not 9006!
jbrams
May 11, 2010 10:30 AM
rob3201
Feb 7, 2007 06:37 AM
Tyltong123
Jun 28, 2006 12:12 AM
GenericPA
Dec 14, 2004 04:31 AM
