Low Beam headlight bulb OR Xenon HID Conversion Kit
Old Nov 7, 2007 | 10:57 PM
kouken's Avatar
Default Low Beam headlight bulb OR Xenon HID Conversion Kit
Consider changing low beam headlight either bulbOR HIDconversion kit. Any recommendations for both Bulb and HID conversion kit are appreciated. Thanks.
Old Nov 7, 2007 | 11:05 PM
Mikes Machine's Avatar
Default RE: Low Beam headlight bulb OR Xenon HID Conversion Kit
Get a cheap HID kit from eBay...they all come as a complete kit. Very easy to install, plug and play.
I just got a kit for my g/f for $75.
I paid $200 for mine a couple of years ago and I've never had a problem except one time one of the bulbs changed color a little bit so I got a new pair, since then it's working great.
They are so cheap now, if it ever gives you hard time, just get another kit or parts...which I doubt it will happen...
and I don't see any differences between expensive($300-$400) and inexpensive(~$75 ebay) ones.
And expensive bulbs cost like 50 bucks...
Old Nov 8, 2007 | 08:39 AM
falkore24's Avatar
I'd say HID, but there are differances in the kits. A kit with an electronic (digital) ballast will outperform and outlive a magnetic (analogue) ballast. Also, they correct the power output to ensure equal lighting. I'd expect a good ebay kit to be about $125-150. For bulbs, I used to have a high power relay setup and 80W low beams and 100W high beams ..... they were pretty powerful. When I changed to TYC projectors, I used the H1 bulbs that they came with for a while and then upgraded to HID. The HID output from the projectors is a bit better than the high power bulbs, but not much. Feel free to look at my pics for an example of my lighting.
hallstevenson
Aug 8, 2013 11:27 AM
andrew7673
Mar 22, 2011 09:24 PM
horsey2k
11
Jul 16, 2008 10:04 PM
LotusDriven
Jul 20, 2007 02:07 PM
Dong
Mar 30, 2007 10:38 PM
