New taillights
Old Oct 15, 2010 | 01:27 PM
andrew404's Avatar
Default New taillights
I installed some new taillights on my 95 accord. After they were installed, the brake lamp light on my dash turned on. All the new brake lights and blinkers are still working though. How do you reset the brake lamp light on my dash??
Old Oct 15, 2010 | 05:59 PM
sanchdaniel's Avatar
I don't believe you can. That comes up as a result of a system check, every time the key is in.
Old Oct 15, 2010 | 06:57 PM
keep_hope_alive's Avatar
did you install LED taillights?
Old Oct 16, 2010 | 10:43 AM
andrew404's Avatar
Yep, they're LEDs
Old Oct 19, 2010 | 10:06 AM
murderdcd5's Avatar
then that is the reason. leds use less power to run and the car is noticing the power difference and is saying the light is out. toi fix this you need to install some resistors to compensate for the extra power. the best way is to find the ohms of the stock tail light and then find the ohms on the led tails. them figure what size resistor(s) are needed and wire them in.
StrikingAccord
Oct 14, 2013 02:17 AM
jmol
Sep 26, 2007 10:29 PM
mega502
Jun 24, 2006 05:30 PM
bovabrandon
Apr 27, 2006 10:19 PM
StreetGlowAccord
Feb 24, 2006 03:59 PM
