Painting trim
Old Feb 9, 2007 | 02:39 AM
HotRodder
Default Painting trim
I have a 99 2dr and I want to eliminate the chrome trim around the windows. I realize that it is part of the weather stripping, but, i'm just going to scuff it and paint it. Does anyone have any pics of this mod? I photochopped it and it looks nice, just wanted to see it for real before i proceed.
Old Feb 9, 2007 | 02:20 PM
millpond's Avatar
Default RE: Painting trim
ORIGINAL: HotRodder
You may have to be the pioneer in this case. Post some photos if you do it!
Old Feb 14, 2007 | 01:47 AM
HuYnHness's Avatar
painting it would give it a sleeker look wouldnt it? oh wells im looking for FLASH haha
Old Feb 14, 2007 | 09:08 PM
adamc44's Avatar
theresan automotive spraypaint called SEM color coat or something like that, they have a color chart that you can use to match it up to your car. make sure you shake it up real good before spraying or a yellow glue type crap will come out. do several light coats letting each one dry completely before spraying the next coat or it will run. ive done bumpers and outside trim before as well as interiorpartswith it and it turned out nice. they also have a carpet dye you can use to "touch up" the carpet in your car if your going to sell it. it last for awhile
Old Feb 14, 2007 | 09:54 PM
OneBright2K's Avatar
I have a 2000 2 dr. that's orange and hated the way the chrome looked so I painted mine black. If you take the moulding on the door off then you'll prob.break the clips but new ones are pretty cheap. Plus itmakes it a whole lot easier. I'll try to post pics soon.
Old Feb 16, 2007 | 01:36 AM
HotRodder
ORIGINAL: OneBright2K
Sweet man, i'd like to see those.
Old Feb 16, 2007 | 01:01 PM
shah
Yeah, man! Post some pictures when you are done. I am sure it would look sleek.
Old Mar 23, 2007 | 03:58 AM
watut's Avatar
Wont work, itll chip off easily.
Old Mar 23, 2007 | 08:52 PM
blaz72282
Proper preparation is the key to getting a paint job that wont chip, crack, or peel. The entire surface must be roughed up with fine sandpaper and cleaned with ano residue solvent. A quality primer must be used, otherwise the paint will fail. After the primer coat, paint with your choice of paint. Several light coats and good technique are key when using spray cans. It seems to me it would be much easier taking the trim off the doors first. then you can really get a good prep job done. Buy some new clips in advance, and If you break a few in the process, you'll have them on hand. Take your time and I'm sure you will be happy with the results. Dont forget to post pics!!! -Mike
wdick6210
Sep 15, 2011 11:40 AM
EkliptStudios
May 12, 2007 10:49 AM
98Accord220HP
Jul 12, 2006 01:00 AM
EMEX
Apr 7, 2006 04:30 PM
