Projectors for the 2007?
Old May 29, 2008 | 06:29 PM
JackTheMetalHead's Avatar
Default Projectors for the 2007?
I've come across these headlight assemlbies on numerous websites. \
http://cgi.ebay.com/ebaymotors/03-04...spagenameZWDVW
I'm very interested in buying these, i'm assuming that they will fit in my 07 since it's the same gen as 03-05? I was wondering if anyone has had these or heard anything about them? The reason i want the projectors is for HIDs later, and beacuse the halo looks sick!
~thanks!
Old May 30, 2008 | 12:05 AM
HORSEPOWERJUNKIE2007's Avatar
Default RE: Projectors for the 2007?
sorry to say but most of the time if those items will not fit if your year is not there.
and just because your car is in the same generation it don't mean ALL parts will fit FOR example,the 6th generation taillights changed in 2001 to 2002 where the red is on top and red is on bottom BUT they won't fit on a 1998-2000 accord even thought they are the same generation so i suggest you take that into consideration before you throw away money.
Old May 30, 2008 | 01:14 AM
03Sleeper's Avatar
Besides, eBay projector headlights tend to burn out within a month. Go the real deal, either HID Conversion Kit (~160-170) or the ultimate overhaul (s2k conversion)
Old May 30, 2008 | 09:02 AM
ok but i originally found these projectors on
http://mytightride.com/hoac2020prhe.html
but i figured i could find them on ebay for less, and they look like the same housing as the link i put in the first post. don't they? I plan on getting HIDs and i want projcetors and i'm not sure how else to do it.
ORIGINAL: HORSEPOWERJUNKIE2007
Old May 30, 2008 | 10:31 AM
finch13's Avatar
Trav20 has the black ones on his 7th gen... his is a 200_
Old May 30, 2008 | 10:53 AM
ORIGINAL: finch13
Has he said anything good/bad about the headlights? I'm pretty sure the ones on ebay are the same as on MTR.com. So would I get the cutoff with those projectors when i install the HIDs? Or would i need to make any adjustments to the projectors? Also i'd like to get a shroud for the projectors from customlightz. I was planning on gettting the HID kit from ddmtuning.com, the apexicone 5000k h1 kit.
~thanks
Old May 30, 2008 | 12:59 PM
finch13's Avatar
You get a cut-off and everything else you would expect from a projector minus the light output quality and cut-off quality.
Old May 30, 2008 | 03:36 PM
ORIGINAL: finch13
That's fine, buying a pair with projectors and halos is cheaper then paying 300 plus more to get a retrofit. I'm pretty sure the ones on ebay are the same as on any other website.
Old May 30, 2008 | 04:22 PM
finch13's Avatar
Yeah, I got random cheap ($130) eBay ones for my 5th gen and they turned out to be higher quality Anzo's. You're looking at much more than $300 for a retrofit.
Old May 30, 2008 | 06:30 PM
ORIGINAL: finch13
Well I guess I'll message the seller and ask if they will fit in my 07. Also customlightz said it would be 300, then shipping I guess would be more
