Question about HID
Old Feb 10, 2007 | 01:37 AM
HuYnHness's Avatar
Default RE: Question about HID
i wouldnt say my 6000k are white they arent as blue as 8000k theyre more if a light blue but id rather that than really blue anyways its bluer than factory hids so its good
Old Mar 29, 2007 | 08:05 PM
03Sleeper's Avatar
any opinions on going 10000k for High beams?
Old Mar 29, 2007 | 10:54 PM
03Sleeper's Avatar
http://cgi.ebay.com/ebaymotors/02-03...QQcmdZViewItem
is it really that simple? just change the bulb??
Old Mar 30, 2007 | 02:53 AM
HuYnHness's Avatar
those look like a nice pair of xenons but theyre not real HID conversion kits
hid conversions kits come with two HID Xenon Plasma bulbs (or watever theyre called) two ballasts to run the bulbs and wires to connect everything. its not quite as easy as replacing a bulb but almost basically i thought the hardest part was lookin for a place to mount the ballasts and mounting them. i hung them on existing screws i jsut tightened it enough so it wouldnt swing around or anything. i should have mounted it better but it works and looks pretty sturdy to me. but yea basically switch your stock bulbs with the HID bulbs mount the ballasts and plug everything up. HID bulbs plug into the ballast and the ballasts plugs into a stock harness. i think i should cover the loose harness but i think it should be fine.
however if you dont wanna spend 100-300 on an HID conversion kit those bulbs are a lil better than stock theyre not as yellow and a bit brighter. cheaper imitation brands might burn out faster than sylvania or PIAA though. the color may look the same but the light output is much better with real HIDs
for example http://hidworld.com/
Old Apr 6, 2007 | 06:09 AM
gcorvette987's Avatar
10000k on my high beams are crazy! man i can see literally for miles, i have had people stop in the middle of the road because they cant see, they wait for me to pass and then they proceed. man its so cool. not to mention on the highway thyre awesome. have you seen my picture? oh i als put green hids in and they ook sick, suprisingly i didnt get pulled over for having them, had them in there for a week but just changed them back to 10000k. ill post pics soon.
Old Apr 8, 2007 | 02:27 AM
pwilkes3's Avatar
ok, so if i want to do HID with my stock headlights, can i just replace the lo-beams with HID since i leave them on all the time anyways. i like the really bright lights i see on the high-end cars these days and i want those bright lights! lol. so whats a good temperature to go with. i really like 10000k but that may be a bit much for a lo-beam. so whats a good compromise between 10000k and something that i'll still get flashed by others for thinking i have my brights on?
Old Apr 8, 2007 | 07:25 AM
  #17
joninja's Avatar
i have bad eyes and i get blinded when cars passing have those lights, i cant stand it. but what are nice looking ones that are street legal and still have a very nice look to them
Old Apr 10, 2007 | 11:15 PM
  #18
03Sleeper's Avatar
http://cgi.ebay.com/ebaymotors/Xenon...QQcmdZViewItem
Is it true you just plug and play? That simple? I thought HIDs burn out the OEM wires and what not. Hence the expensive HID conversion kits....
Old Apr 10, 2007 | 11:55 PM
  #19
HuYnHness's Avatar
well the HID conversion kits are pretty much plug and play for the most part besides mounting the ballasts. the cheap "HID" bulbs on ebay arent real HIDs theyre just halogen bulbs with a bit of xenon gas to make it a bit brighter. and since HIDs only take 35W instead of 55W or 100W some "HID" bulbs use they shouldnt burn the oem wires. i believe its 35W in total but stocks lights are 55W each bulb
BTW 03Sleeper what bulbs are you running in that picture?
Old Apr 11, 2007 | 12:34 AM
  #20
03Sleeper's Avatar
[ul][*]Hyper White, 12V, 5000K, 100-Watt, 9005[*]Hyper White, 12V, 5000K, 55-Watt, 9006[/ul]
9006 is low beam, 9005 is high beam. 9006 is whiter than 9005.
An D. Nguyen
Aug 13, 2013 09:59 PM
lexuslover04
Jan 12, 2011 03:52 PM
Dj Insanity
Jun 2, 2007 10:54 PM
kennilope
Apr 7, 2007 02:30 AM
kgh31386
Jun 3, 2006 01:41 AM
