New here, question about HID's
Old May 29, 2006 | 02:14 AM
kgh31386
Default New here, question about HID's
If I have a 9006 HID kit, will that fit into a stock 03-05 Accord? And i've seen those retrofits on ebay, but it won't say bulb size. anyone know a company that sells 9006 sized retrofits? and if i just put the kit into my reflective housing, will it cause glare or would it look good?
Old Jun 1, 2006 | 12:00 AM
JorgeRH
Default RE: New here, question about HID's
Do a search, b/c there's definitely been some talking about this in the past. Go for the 9006/9005 McCulloch HID kit, depending. it should be fine in the regular housing, but I've heard there are possibilities that it could melt the housing, but I don't know. 9006 is for the low beams, 9005 is for the high beams. On the 03-05, you have to remove the battery to get to the driver side headlight, know this, it sucked when I found it out. When you unplug the battery of your car to get to the driver side headlight, and plug it back in, go to the stereo, it will ask for a code to make the stereo work again, call Honda, there's a number inside your glove box right on the inside lip on a sticker, give a honda tech that number and they can look up and give you the code to punch in to make your stereo work again, then NEVER lose that number. Good luck, let me know how it turns out.
Old Jun 3, 2006 | 01:41 AM
cmt7011
If you havent gotten an answer yet i can help you. Yes but make sure you stick it inot the low beam light the high beams are 9005. I made the mistake my first time. lol Good luck hope that helps.
An D. Nguyen
Aug 13, 2013 09:59 PM
Aug 29, 2011 04:38 PM
AccordV62006
Aug 4, 2009 11:28 PM
Bacondoggy
Jun 16, 2009 07:32 PM
noboundaries6289
Jan 2, 2008 12:35 PM
