speedo wont work
Old Dec 12, 2007 | 01:51 PM
PCHonda
Default speedo wont work
hi, folks.. newbie here with a problem. 96 accord lx 4dr. speedo got an attitude problem where it works either when it wants to or at 70 mph on the interstate. how can i fix it?
Old Dec 12, 2007 | 08:48 PM
trukid21's Avatar
Default RE: speedo wont work
welcome, does your cruise control still works? if it does,it could be your speedometer gauge might be messep up.either you get a new speedo assembly or if there is a shop that repairs speedo then check them out. if your cruise control does not work,you probably need a new VSS vehicle speed sensor. i had the same issue with my car. i replaced my instrument panel and luckily the odometer with the replacement i got from a honda/acura salvage shop was only 10 miles off, lucky i say. i used to use my RPM gauge to know how fast i was going. i take a note when my speedo works then i compare it to my RPM. i got used to it for a while even after i had it replaced.goodluck and i hope u get it fixed.
Old Dec 13, 2007 | 09:08 AM
PCHonda
thanx, will hit the shops asap.
Old Dec 13, 2007 | 09:16 AM
falkore24's Avatar
check the coil as well!!!
Old Dec 13, 2007 | 09:54 AM
PCHonda
where do I locate the coil? i'm just getting the hang of figuring out my car's functions.
imdrivingahonda
Jun 9, 2013 10:56 AM
spidremedia
Sep 12, 2008 11:53 PM
Xv7vX
Jan 15, 2008 05:25 PM
isxtexas
Dec 8, 2007 11:27 PM
a1orientalrug
Nov 17, 2005 05:07 AM
