Tail light tiniting
Old May 29, 2007 | 11:56 AM
Git2fast's Avatar
Default Tail light tiniting
Does anyone happen to know anyone that can do spray on tint for tail lights, please let me know
Old May 29, 2007 | 02:41 PM
Default RE: Tail light tiniting
can do it yourself, i did
Old May 30, 2007 | 10:57 AM
CoryTheStory's Avatar
I did too
Alot of people here have, we can tell you how if you'd like.
Old May 30, 2007 | 11:31 AM
19Accord97
It is easy! Its only like $12 a can. The only thing that matters is patience and a clean surface.
19Accord97
Old May 30, 2007 | 04:51 PM
Dj Insanity's Avatar
ORIGINAL: CoryTheStory
I did too
sure.. id like to no cause im considering doing it myself!
Old Jun 1, 2007 | 02:57 PM
You'll need to buy some Nightshades which is a special spray on tint made for tail lights. You canfind it on ebay or some people find it at certain shops. One can should be enough for most cars. Also buy some clear coat from home depot or somewhere.
Then remove your tail lights, tape off any area you don't want covered with masking tape and apply several even coats of the nightshades depending on how dark you want them. Wait about 20 mins between each coat. I only tinted the middle part which only holds my reverse lights and extra brake lights so I made it very dark. If you're tinting all the lights you may want to put less coats as to not make them so dark that other drivers can't see them (although mine still shine through like it's noteven tinted). Once u have them as dark as u'd like (I suggest taking them outside in the sunlight and holding them somewhere close to where they will go back in) apply SEVERAL coats of clear coat. (I put 9 coats on)You will most likely have to wait longer between coats, read instructions on can. Then let dry, remove tape and re-install. Failry simple. Some people say you should wet sand a couple times throughout the process, I didn't fnd it necessary.
Do this in a highly ventilated area, i don't want anybody dying cause of me lol.
Old Jun 1, 2007 | 07:55 PM
accord93's Avatar
I GOT IT(NITESHADE PAINT) AT O' REILY'S AUTO PARTS 4 $12 turned out great but i still dont have pics : /
Old Jun 2, 2007 | 11:44 PM
HuYnHness's Avatar
is that stuff removable? i kinda want to try it to see if i like it. the plastic tint is too expensive for a trial run
bobbybriggs01
Aug 21, 2013 06:14 PM
myfirstisanaccord
Apr 24, 2011 08:25 PM
bigdude
Oct 1, 2006 07:03 AM
supa_accordv6
Nov 30, 2005 11:33 PM
90AcrdGurl
Nov 26, 2004 10:56 PM
