Trunk interior
Old Feb 22, 2009 | 07:57 AM
Azrael's Avatar
Default Trunk interior
I am in the process of Cutting a new trunk floor from 3/4 plywood and carpeting it to replace the factory trunk insert and plan on screwing it to the trunk floor. The amp will be mounted in front of the sub box which will be bracketed to the floor to prevent it from moving around with holes drilled for the amp wires and covered up by the end caps of the amp. My question is...... where is the gas tank? Id hate to accidentally drill right into it. Thanks in advance to the usual people.
Old Feb 22, 2009 | 04:29 PM
finch13's Avatar
You shouldn't hit the tank if you accidentally screw into the floor. When I did my plywood trunk thing, I made L brackets out of oak trim (won't split) and ground off the rest with a grinder. I used 1/4" plywood, if you go 3/4" I'd use countersunk bolts coming up and nylon locknuts.
Old Feb 22, 2009 | 04:44 PM
Azrael's Avatar
I goofed. It was 1/4" and I ended up using sheet metal screws with the little lock things on the underside. Now i Just have to get some carpet.
Old Feb 23, 2009 | 05:29 PM
Azrael's Avatar
Pics up!
Old Feb 23, 2009 | 05:31 PM
lol the previous owner of my car drilled right into the gas tank installing the false floor.
Old Feb 23, 2009 | 05:33 PM
Azrael's Avatar
Must be the same guy that drilled into my bumper to put up his car lots sign.
Agregory88
Dec 9, 2012 09:54 AM
thaison86
Jun 28, 2012 12:03 AM
drew&dixon1718
Nov 29, 2011 09:31 PM
sosaman
Oct 7, 2007 11:28 AM
MNHONDAGUY
May 8, 2007 07:52 PM
