07 accord no display on radio
Old Jan 13, 2012 | 03:35 PM
vral81's Avatar
Default 07 accord no display on radio
Hello everyone. I have 2007 accord SE V6. CD player in my car went out about 6 months ago but the radio was working and display was working fine also. Well I removed this radio to check it out to see if there is anything I could do to fix my cd player but when I plugged it back in, the display went out. Now everything is down, clock display, radio and cd player. So I decided to bought a used radio similar to the one I have in my car from a local seller. When I plugged that, even that didn't turned on, no display. So I checked the fuse under by floor mats and fuse appeared to be good. I don't know what to do now. BTW my air controls are working. Is there anything else I can check to see? Thanks. Any helps will be appreciated.
Old Jan 14, 2012 | 08:23 AM
keep_hope_alive's Avatar
i assume you either left something unplugged, blew a fuse, or the harness isn't fully inserted. you need to test fuses with a DMM - by measuring voltage on both sides (that is what the small metal tabs are for on the top of the fuse - so you can measure while inserted)
Old Jan 17, 2012 | 02:44 PM
vral81's Avatar
Sorry for delay in response. I made sure that the harness was fully inserted and I tested with two different units both ended with same results no display. I am not sure about the one I bought off of ebay but I know that the one I had installed had display working until I put it back in so apparently there might be something that is preventing the display to come on. Could there be something related to anti-theft? I have not tested the fuse with DMM yet but I will do that and post the results here. Thanks for your response.
hondaowner
Apr 23, 2022 12:48 PM
maroo
Nov 18, 2010 10:25 PM
GregSC
Jan 28, 2010 01:04 PM
bodegas411
Jan 15, 2008 10:31 PM
europeanboy
Jan 1, 2007 07:51 PM
