09 accord with anc
Old Jan 17, 2010 | 01:50 PM
tjs723's Avatar
Default keep hope
I'm not going to get Navi....... and I've seen in antoerh forum that i would retain the Temperature display in the upper screen because they're on a different circut! I've seen a pitcure and the screen is blank except for the 2 Temp display at the bottom 2 corners!
And yes, Im going to install a full aystem. I found an installer that says he's done this type of install before. They key seems to me to make sure that the ANC plug in the wiring harness is NOT connected. That defeats it and so no problem!!
Again......... THANK YOU!!!
PS........... the picture you show is the same color im getting in a white coupe
Old Jan 17, 2010 | 03:17 PM
keep_hope_alive's Avatar
^that makes sense. if you're not using factory Navi/Bluetooth and are willing to not use the screen for anything else it's as simple as getting a kit.
Metra 99-7875 or 99-7875T
apmech
Sep 18, 2016 04:21 PM
HunterG
Jun 8, 2015 12:28 AM
Phil Lederer
Jul 30, 2013 10:56 PM
dking99
May 20, 2009 09:09 PM
