1999 honda accord v6
Old Jul 6, 2022 | 09:07 AM
Therealdonjerz's Avatar
Default 1999 honda accord v6
So I'm driving and my battery light, ebrake light, and open door warning lights come on flickering, but the car is running perfect though, what can cause this after I replaced the alternator, motor mounts, battery terminals, new battery like at this point I'm confused 😕. I need some input plz before I run this car into a wall.
Old Jul 6, 2022 | 10:37 AM
shipo's Avatar
Speculation leads to throwing parts at a problem hoping you guess correctly; in most cases, including yours, this is not a cost effective approach. I would strongly suggest you take the car in and get the codes read and have it professionally diagnosed.
Old Jul 16, 2022 | 10:33 AM
keep_hope_alive's Avatar
One of the areas of concern with that work is something loose or a bad ground. Go back over your bolts, re-tighten, and make sure the engine-to-chassis ground is in good shape. I added a ground that connected from the factory chassis ground (under the air box) to the engine block/transmission housing. There are some unused threaded holes there for an M6-M8 bolt.
FREExMIND
Nov 8, 2020 04:35 PM
Brandon McCullough
Feb 22, 2019 06:54 PM
Mr. 99
Feb 6, 2019 04:56 PM
pm92508
Jan 31, 2012 07:29 PM
