2001 Accord OEM Stereo Replacement
Hello
I have a 2001 Honda Accord EX V6 with the stock OEM Radio (01 02 Honda Accord 6 Disc CD Cassette Player Radio | eBay) .There is nothing wrong with the system but still I want to upgrade to a newer system for extra features like BT, USB playback, etc. I am thinking of buying this Pioneer stereo (
Amazon.com : Pioneer FHX-720BT 2-DIN CD Receiver with Mixtrax, Bluetooth® for Hands-Free Calling and Audio Streaming, Siri Eyes Free, USB Playback, Pandora, Android Music Support : Electronics
). I have a couple of questions.
- It is a 2-DIN system so I am guessing the pioneer system should fit?
- If it doesn’t fit where can I buy mounting kit/brackets to make it fit?
- I think I will also need an adapter/converter since I am going from OEM to non-OEM radio?
- Any other wires/kit I need to order before replacing the stereo?
Thanks in advance.
Sunny
Thanks in advance.
Sunny
the mounting kit and wiring harness are additional expenses. if you buy a replacement from Crutchfield, they will include the mounting kit and wire harness adapter you need, with instructions on replacing. Based on your questions, i think they are a good vendor to use. if you want to buy each part separately, visit Metra Online | Welcome to Metra Auto Parts Online Warehouse and enter your vehicle information for a list of mounting kits and wire harnesses. installation instructions are available for free download.
I prefer Alpine stereos, personally. What to get depends on your desired features and budget.
i recently sold my 2001 EX V6, and did a ton of mods to it as well as maintenance/repairs. i'm happy to answer any questions.
Thanks for the reply. I ordered the Metra harness and bracket and plan to do installtion next weekend. Is there any manual or video I can refer to? Also, I have been told by my friend to run my own ground. Is it necessary? I thought that the wire harness would match all the connections including ground.
the factory harness has a ground wire that can be used. i also run a dedicated chassis ground. the factory ground wires are tiny.
you can reference the install manual for the Metra mounting kit - the instructions are available on their website. that's as complicated as it is.
my youtube channel has some videos on making good wiring connections - applicable for connecting the metra harness to the head unit harness.
yep, those connectors are made for the job. i prefer a soldered connection, but not everyone is comfortable with soldering wires so that's where the posi-loc connectors come in.
i wire houses with WAGO nuts instead of the traditional twist wirenuts. gotta embrace modern methods.
Alright, I ended up buying Sony WX-GT90BT car stereo.
Hooked up everything (with some help from your video) and it looks good.
Everything works EXCEPT the radio. This unit has a connection for XM but I just want to run regular radio. The metra wiring harness has a "blue" wire for antenna but the Sony Headunit harness does not have any wire that says antenna. The blue wire on sony side says REM OUT (which I think is remote amp wire).
When I dissembled the stock unit, there was a separate wire going into the unit. I thought that was the antenna wire but didn't see a place to put it. I put it in the XM "jack" in the sony headunit but the radio still does not work.
Any ideas/suggestions on how to fix it?? I think I am missing something really basic.
As an extra question out of curiosity, what would have happened if I had not removed the battery connections while assembly.
if you leave the battery connected you just run the risk of shorting out a wire and blowing a fuse. if you make the harness connections ahead of time, then there isn't a concern swapping plugs.
