2002 Honda Accord SE LED Conversion
Old Jul 19, 2013 | 06:51 PM
csh217's Avatar
Default 2002 Honda Accord SE LED Conversion
Could anyone inform me the size bulbs I will need in order to convert my car's lights to LED lights. Also where is a reputable vendor to buy from? Lastly, which is better LED or SMD LED? Obviously I am new to this so any information will help.
Old Jul 19, 2013 | 07:36 PM
5.56mm_hickey's Avatar
my opinion, just keep the lights abd assemblies oem, honda has done a good job of mixing there assemblies with body style, just my 2 cents. modern lighting with older cars can make or break appearance and performance
Old Jul 19, 2013 | 11:21 PM
keep_hope_alive's Avatar
the bulb types in the gauge cluster are pretty specific, they rotate in place and have a specific back-piece. the LED retrofits i've seen were done by soldering LED's in place of bulbs and adding SMD resistors for the required drop. End result can be great, but very time consuming.
These are examples of stock gauge cluster bulb locations/types:
1998 02 Honda Accord Bulb Kit for Speedometer Instrument Cluster Dash Gas Temp | eBay
1998 02 Honda Accord 4 Bulb Kit for Indicator Dash Check Engine Turn Signal | eBay
or are you talking about courtesy lighting?
2pcs HID White 168 194 T10 921 LED Bulbs Side Under Door Courtesy Lights 07 | eBay
White LED Door Courtesy Light 6 SMD Easy Fit Bulbs T10 194 168 2825 Qty 2 | eBay
SMD LED's are typically much brighter with more output than T5 or T3 LED's, but also more expensive. so choose based on your desired output.
Old Jul 19, 2013 | 11:24 PM
Old Jul 20, 2013 | 11:41 AM
csh217's Avatar
Thank you for your informative reply.
Old Aug 2, 2013 | 01:45 AM
I did buy the kit I linked. Arrived as described and everything fit. Here are my install photos:
before:
aluminum foil tape in the housing to reflect light out
does much better
Old Aug 2, 2013 | 01:46 AM
man, that rear door is dirty!
98accordman
Mar 15, 2020 01:34 PM
Cody_754
Aug 19, 2012 11:21 AM
piggylover1985
Aug 28, 2010 07:38 PM
Tippman7641
Dec 24, 2008 09:20 PM
Cobey
May 6, 2007 02:07 AM
