2006 Aftermarket Install Kits
Old Jul 30, 2011 | 05:42 PM
befumo's Avatar
Default 2006 Aftermarket Install Kits
I am looking for a kit that actually removes your factory radio but actually looks good at the same time. I hate that one where it moves the climate controls up..
http://imageshack.us/photo/my-images/380/dsc00858vs7.jpg/sr=1
I just think it looks cheap.. Are there any others? I have seen the one where it moves it to the very bottom, but again it looks ridiculous then the car has two radios?
Would like to know if there any other kits, willing to pay a decent amount. Getting sick of fumbling around with CDs after having an aftermarket stereo in my Jeep.
Old Aug 2, 2011 | 11:51 AM
keep_hope_alive's Avatar
best looking kit will be custom made. the plastic kits all look cheap. find a good shop that does great custom work for show cars.
Old Aug 27, 2011 | 02:23 PM
befumo's Avatar
Really you have seen this done? How expensive do you think that would be.
I just cant believe nobody makes a trim piece that does not remove them.
Anyone done anything else as far as custom decks?
Old Aug 29, 2011 | 09:55 PM
custom dash mounts are done routinely by good shops - start with ABS plastic, add some body filler or fiberglass, sand, fill, repeat, then finish with paint to match the interior.
that said, you could start with the plastic kit then use body filler and some careful sanding to get a better finish, then paint to match. what i don't like about the plastic kits are they they aren't solid. i prefer to use the factory radio brackets that will screw into the ISO mounts on the head unit (single or double din). then make a trim piece around that.
i'm doing that on my Accord. I have the ABS plastic trim ready to be glued to the factory deck opening, then just fill and sand then paint. not sure when i'll complete this as there are several other items higher on the to-do list.
Nightviper19
Mar 15, 2008 10:45 AM
Nekozuki
Mar 3, 2008 11:13 PM
dally41888
Dec 2, 2007 11:53 AM
jprez1980
Apr 3, 2007 02:57 PM
trihonda
Aug 6, 2006 12:53 AM
